RTX 2060 issue
Solved by Elonn,
1 minute ago, kdawwgg1221 said:The seven expansion slots in the back below your motherboard I/O Shield.
Yes it is plugged there is what I meant, but what do you mean connecting monitor to GPU? My monitor is VGA using a VGA to HDMI adapter that is connected to IO shield.
My GPU is installed if thats what youre asking since the fans spin and motherboard reads it
