So I posted about some premade builds the other day, and I just decided that I'd build my own, and I will probably have a budget of around $800-900, is there any tips for how I should proceed? My only intentions are to run Black Ops 3, League of Legends (I know this is absolutely easy to run), and CS:GO all on high graphics. I don't need anything super high tech, just a medium PC build that will get the job done. Thanks! (Is this in the right forum? I have no idea)
https://linustechtips.com/topic/1094551-need-help/
I'd go with a Ryzen 3600 and RX 580 build myself.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1094551-need-help/#findComment-12811914
What resolution and FPS are you shooting for?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1094551-need-help/#findComment-12811932
9 minutes ago, AndrewTaylor1999 said:
From what I've seen, the RX 580 looks very good, but would the RX be better paired with a Ryzen vs Intel? Like what is the difference? Thanks !
the difference is in the single percentage points, in fact, if you can I'd grab a 1600/2600 because they are fine chips and can be had real cheap.
https://linustechtips.com/topic/1094551-need-help/#findComment-12811937
3 minutes ago, AndrewTaylor1999 said:
1920 x 1080 and somewhere around 70-90 FPS I don't see the difference above 60 but I want to be safe and have higher.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1094551-need-help/#findComment-12811938
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($133.00 @ Amazon)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($114.89 @ OutletPC)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($79.99 @ Amazon)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: MSI GeForce GTX 1660 6 GB GAMING X Video Card  ($224.99 @ Newegg)
Case: Aerocool Cylon ATX Mid Tower Case  ($52.53 @ Amazon)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($69.89 @ OutletPC)
Total: $784.18
Generated by PCPartPicker 2019-08-15 23:43 EDT-0400
i choose 2600 over 3600 so you can make it cheaper while maintaining the gaming performance. i bet this one its good for money. but you can swap the CPU to 3600 actually.
i can make it cheaper for that kind of game-like around 500-600 if you want it.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1094551-need-help/#findComment-12811948
1 minute ago, hello_there_123 said:
You do know , that this is nearly identical to the 660p , right?
Yes, i couldn't find it on the list lol until after i submitted it
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1094551-need-help/#findComment-12811949
Total: $784.18
Yes absolutely! As cheap as I can get, I just want a max of $800-900 as I really don't know what type of parts i need for those games so anything even as a starter is perfect. Thank you!!!
https://linustechtips.com/topic/1094551-need-help/#findComment-12811958
Just now, Wolfycapt said:
3000mhz cl16 2x8 team vulcan is at $62... and cl15 vs cl16 does not matter
ex900 at $50...
2 minutes ago, Wolfycapt said:
Formula gold 550 is the same price on newegg. And insanely better quality.
https://linustechtips.com/topic/1094551-need-help/#findComment-12811959
ex900 at $50...
i kinda go with best quality i guess. but like i said i can make it cheaper. idk about Formula Gold 550, thx for telling me.
can i get full list of game? most of my build based on game actually
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1094551-need-help/#findComment-12811964
mainly Black Ops 3, League of Legends, CS:GO, Maybe Black Ops 4, Star Wars Battlefront 2, Battlefield 1, stuff like that
https://linustechtips.com/topic/1094551-need-help/#findComment-12811969
If you want to go cheapest...
https://linustechtips.com/topic/1094551-need-help/#findComment-12811973
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($79.89 @ OutletPC)
Motherboard: ASRock B450 Pro4 ATX AM4 Motherboard  ($89.89 @ OutletPC)
Memory: Team Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($41.99 @ Newegg)
Video Card: MSI Radeon RX 570 8 GB ARMOR OC Video Card  ($139.99 @ Newegg)
Total: $539.17
Generated by PCPartPicker 2019-08-16 00:06 EDT-0400
The b450 pro 4 is commonly used in a budget build tho, and the RX570 perform similarly with 1060 wit cheaper price. 2200 is basically enough for 570. if you want more future proof than i suggest to go ryzen 5
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1094551-need-help/#findComment-12811979
I'll recommend something like this instead...
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($198.90 @ OutletPC)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($74.99 @ Newegg) This board supports Zen2 CPUs on all of its BIOS revisions. So, no BIOS update needed.
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($49.99 @ Newegg)
Video Card: Sapphire Radeon RX 5700 XT 8 GB Video Card  ($399.99 @ B&H) Placeholder for aib varient
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ B&H)
Power Supply: Cooler Master MasterWatt 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($64.43 @ Walmart)
Total: $903.28
Generated by PCPartPicker 2019-08-16 02:43 EDT-0400
This is a 1440p capable rig. you can settle down with a rx580 if you dont need the extra horsepower.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1094551-need-help/#findComment-12812192
No need to spend that much. Play all those games at high on something like this,
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  ($84.89 @ OutletPC)
Memory: Team Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($36.89 @ OutletPC)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  ($66.95 @ Adorama)
Case: Cougar MX330 ATX Mid Tower Case  ($39.99 @ Amazon)
Power Supply: EVGA BQ 500 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($54.89 @ OutletPC)
Total: $556.60
Generated by PCPartPicker 2019-08-16 03:02 EDT-0400
https://linustechtips.com/topic/1094551-need-help/#findComment-12812220
Total: $903.28
I want an RX 580, how do I know which video card to use? Like I'm on parts picker and theres all of these different videos w/ the RX 580 chipset, how do I know which one to use and which one is good? Thanks!!
https://linustechtips.com/topic/1094551-need-help/#findComment-12812924
I'll recommend Sapphire.
https://pcpartpicker.com/product/y2DzK8/sapphire-radeon-rx-580-8gb-pulse-video-card-11265-05
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1094551-need-help/#findComment-12812981
