My Pc Specs:
Geforce GTX 1660
FX 6300 cpu
MSI 970 motherboard
8 gigs of ram
I recently switched over to pc gaming a couple of days ago and I get anywhere from 30-110 fps while playing fortnite and my gpu and cpu usage are very low with my cpu usage being at 39 consistently and my gpu being at 26-28 and i dont know what to do about it. Is my cpu bottlenecking my gpu? Please help.
Yes, your CPU is bottlenecking your GPU. The FX 6300 will be a bottleneck in virtually any modern game when paired with a card exceeding the performance of a GTX 960. Low CPU/GPU usage rarely determines your frame rate, as most games will not hit 100% utilization.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
Is there anyway I can get the usage up without getting a new cpu. If not what would be a good cpu that would go with the motherboard that I could get that’s not too expensive?
Increasing GPU usage will not yield better framerates. The AM3+ platform is dead, there is no upgrade path that would be suitable for your current card. Your best bet would be to switch to AM4. I would look on your local classifieds (Facebook Marketplace, Craigslist) for people trying to get rid of their old Ryzen 5/7 CPUs, B350 motherboards, and DDR4 memory.
Desktop
Homelab
Thanks I appreciate the help it means a lot!
