Can't make my RAM sticks work on 1w3/2w4 slots. Bought same motherboard new, same RAM's new, the system won't boot when they are in this cfg(1w3/2w4). Currently in 3w4 slots, I've checked Cpu for bents, doesn't seems to have any, I've tried each slot simultaneous, 1 and 2 looks to be dead when in use as the system won't boot. Any suggestions ?
Rig: Mobo Z270-p
i7 7700k
2x8GB ddr4 2400mhz hyperX
1080 8GB Gigabyte
https://linustechtips.com/topic/1094292-need-some-help-with-ramslots-compatibility/
32 minutes ago, NewUser69 said:
just edited one, tho it's not so clear, hope you can understand what i mean from it
What about A2 B2 slots?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
first 2 empty slots in the pictures are not working, the next 2 are with my RAM sticks, it doesn't run in dual channel mode so I'm losing a lot of performance like that, I can't find a fixing
If the slots aren’t working can you RMa the mobo?
4 hours ago, NewUser69 said:
if by that you mean return, i already bought same motherboard and it has the same problem
Maybe it’s faulty ram sticks?
try a2 B2 a1 B1 again
