I want to pruchase a new CPU (incl. Mobo, RAM , etc) at the end of this year.
My question is, since I'm primarily gaming on this pc. What should I get AMD Ryzen or Intel ?
I was looking at the 3700x and the I7 8700k.
I'll be getting 16 GB of DDR4. I'd need suggestions for this aswell.
I was looking at this:
https://www.mindfactory.de/product_info.php/16GB-Patriot-Viper-Steel-DDR4-4000-DIMM-CL19-Dual-Kit_1309477.html
Will my PSU be sufficient?
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    MSI MAG B550 Tomahawk
  • RAM
    Patriot Viper Steel 4400CL19 @ 3800 CL17-17-18-38 1900 FCLK
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
    Western Digital 1TB HDD + Toshiba 2TB HDD + SanDisc 256GB SSD + Samsung 1TB 970 Evo (Main)
  • PSU
    Corsair 530W Gold
  • Display(s)
    AOC 2460G4 + LG Flatron E2341
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
    Beyerdynamic DT990 + Modmic
  • Operating System
    Windows 10 Home 64Bit
https://linustechtips.com/topic/1094075-need-advice-for-new-cpu/
DDR4 3600Mhz with the lowest CL timings you can get is the sweet spot for Zen 2, and I'd defo go with the 3700X. Considering the 3600/3600X match the 8700K, slapping 2c/4t more on top of that makes it even better.
What PSU are you running, and what's your budget for a mobo?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
2 minutes ago, Drachenmaetzler said:
3200mhz RAM is fine unless there's some 3600mhz RAM with low timings for sale.
Just buy Ryzen 3000 with one of the mid range ASUS or Gigabyte Boards.
Just now, Zando Bob said:
DDR4 3600Mhz with the lowest CL timings you can get is the sweet spot for Zen 2.
Yeah I was going to get the CL down on the RAM I was showing.
Quote
530W Gold?
Quote
What about Single Core , AFAIK Ryzen's still behind considering I could easily get 5GHz on the Intel CPU.
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
530W Gold?
A 6c/12t chip matching/beating another 6c/12t chip means the single core perf is the same. You can get the 8700K to 5Ghz yeah, but that extra 300Mhz won't make much of a performance difference, it's already boosting to 4.7 stock, and the Zen 2 chips do slightly lower than that at stock and still match it on the single core IIRC. Unless you really love manually overclocking (for Ryzens it's still better to tweak the boost and not force a manual all-core OC), the Zen 2 chips are the better choice for most use cases.
What 530W Gold? That's just a wattage and efficiency rating, what model is the PSU? There's crappy PSUs and solid ones with the same wattage and efficiency ratings, need to know the model to see if it's a decent one or not.
Mouse: EVGA X17
Corsair CX500 M ? idk can't look into the case.
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
Quote
About 150-200€
offtopic: how do I change my signature :'D
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
1 minute ago, Drachenmaetzler said:
About 150-200€
That may be enough for an X570 mobo depending on the pricing there (the $200 USD lower end boards use the same VRMs and have most of the features of the more expensive ones, so there's no real need to spend more), otherwise an MSI B450 Tomahawk or Gaming Pro Carbon is the best choice IIRC. X470 doesn't do much other than give you SLI support, X570 gives you PCIe 4 if you wanna get the new even speedier NVMe SSDs later on.
It's in a weird spot, IIRC it's how the forum software is built, not LTT's choice.
Mouse: EVGA X17
1 minute ago, Zando Bob said:
THX.
Yeah probably gonna go for X570 just to be on the safe side.
M.2 will be a thing to consider aswell.
Thanks for the help so far!
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
THX.
Look up Buildzoid's video on the GamersNexus channel, he does ones for each chipset and has one up for X570, explains why the $200 boards function the same as the ones that cost twice as much. And if you don't need to save money, I'd defo go for a solid X570 board, they're not 100% needed but it's nice to know you've got all the features of your CPU available.
Mouse: EVGA X17
Alright,
Updated my Signature to my current Specs btw.
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
Alright,
Nice! If your PSU is a grey label CXM or CX you'll be fine, if it's a green label one I'd replace it.
Mouse: EVGA X17
Oh well. Guess I'm changing that too.
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
F. Should be worth it though, if the PSU goes out it can take the rest of the system with it, and that costs a lot more to replace than getting a new PSU in the first place. You can just get a new grey label CX or CXM, the RM/RMx/i/TXM/etc series from Corsair are solid as well, so are the G2s from EVGA (and the P2 and T2 but those bois get really expensive). That's about where my knowledge of good PSUs stops, though I do know the Seasonic Focus Gold PSUs are to be avoided, they have issues with hungry GPUs like the vega cards spiking in wattage, would be fine with a 1080 though.
Mouse: EVGA X17
Ok thanks for the help.
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    ASUS GTX1080 STRIX
  • Case
    NZXT H440 Black/Red
  • Storage
  • PSU
    Corsair 530W Gold
  • Display(s)
  • Cooling
    Corsair H115i Pro
  • Keyboard
    Corsair K70 RGB
  • Mouse
    G403
  • Sound
  • Operating System
