Help and question ( ͡° ͜ʖ ͡°)
Micropoint
Hello people so i have some question. ( ͡° ͜ʖ ͡°)
Should get my pc end of month.
that.
So the question i have first are about windows, i wanted to install an optimised version of win 10 LTSC but the build is v1809 build 17763.437 and its recommended to get the 1903 build.
Do you agree with that ?  If yes wich win 10 version do you recommend me ? home or pro ? Thanks.
Driver questions now.
Mobo is x570 ASUS prime pro, we recommend me to flash it except if the mobo is already up to date ( about driver )
this one right ? if flash needed for sure. 2111507998_bandicam2019-08-1217-21-05-787.jpg.a3141adc4e158b6b0d63cd775c82c574.jpg
So i flash the mobo if i dont see lateste bios update ok good from here.
Then. graphic card driver not a problem too, that one is correct.
Then should i install everything you see here ?
AMD Chipset Drivers
Revision Number
1.07.29.0115
File Size
50.8 MB
Date de version
31/7/2019
Driver Details
AMD RAID Installer (SATA, NVMe RAID)
Revision Number
9.2.0.127
File Size
267 MB
Date de version
31/7/2019
Driver Details
AMD RAID Driver (SATA, NVMe RAID)
Revision Number
9.2.0.127
File Size
1.26 MB
Date de version
31/7/2019
Driver Details
AMD StoreMI Technology
Revision Number
1.5.0.21578
File Size
75.9 MB
Date de version
7/7/2019
About processors now, well this one for sure. Do you agree ? me too ( ͡° ͜ʖ ͡°)
This is where i am not sure at all. ( you know last real pc i ad was in 2008/2009 i loose my computerino skill when it come to these thing )
So should i also install that from ASUS website.
AUDIO
Version 6.0.1.86662019/07/0380.68 MBytes
Realtek Audio Driver
V6.0.1.8666 for Windows 10 64-bit
to get sound from mobo so needed even if i will use an external sound card. ( ͡° ͜ʖ ͡°)
LAN
Version 12.18.8.222019/08/012.57 MBytes
Intel(R) Gigabit Ethernet Driver
Install Intel(R) Gigabit Ethernet Driver.
to get internet so needed ( ͡° ͜ʖ ͡°) Because without ethernet i'll just die. ( ͡° ͜ʖ ͡°)
Utilities
Version 3.00.112019/07/3065.38 MBytes
EZ Update v3.00.11
Support OS:Win10 64bit
easy update ? ( ͡° ͜ʖ ͡°) i think i can avoid installing this s**t am i right ? ... ( ͡° ͜ʖ ͡°)
Chipset
Version 1.7.29.01152019/08/0249.87 MBytes
AMD Chipset driver
- Fixed Destiny 2 application launch issues.
- Updated AMD Ryzen Balanced power plan
- Update AMD chipset driver 19.10.xx first before update this driver
Got chipset update from amd website, wonder to know wich one should i install ? ... From amd or asus ?
SATA
Version 9.2.0.1052019/07/03230.96 MBytes
AMD RAIDXpert2
V9.2.0.105 for Windows Win10 64bit---(WHQL)
Qualified Vendor List
Version -2019/07/30748.88 KBytes
Memory_QVL_2nd_Gen_AMD_Ryzen_Radeon_Graphics_X570
What is this ? o_O
Utilities: AURA Lighting Control
to synchronize RGB ok i got that.
English is not my native language, i hope you understand me well. ( ͡° ͜ʖ ͡°)
Thanks again for your time help and patience. This forum is amazing including this community for sure.
take care.
You only need chipset, audio and LAN. And usually not even those as Windows installs drivers along with updates. You need enterprise version of Windows to get long term support version. It is not for consumers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
hi there.
so all stuff from asus > i avoid them and i take the one from AMD website instead, and for sure flash the mobo first.
i mean i only take audio and lan from asus website, for the rest >> amd website.
2 minutes ago, Micropoint said:
hi there.
I prefer mobo's versions of drivers. Mainly as they are tested and verified with mobo.
about mobo driver its from asus website for sure, i am talking about that one, but maybe the mobo will come already up to date so will see in time...
>>> https://www.asus.com/us/Motherboards/PRIME-X570-PRO/HelpDesk_BIOS/
I downloaded all stuff i need that way it will be faster.
You don't need anything RAID if you aren't going to use software RAID.
updated.
( ͡° ͜ʖ ͡°)
Thank you.
Not needed ?
i know i ask lot of question, but i like to do thing correctly. ( ͡° ͜ʖ ͡°)251125616_bandicam2019-08-1319-27-25-662.jpg.7b016c8673bd2a29f6c17fd0a6ac05bd.jpg
1 minute ago, Micropoint said:
Not needed ?
You keep using ( ͡° ͜ʖ ͡°), I do not think that means what you think it means.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
lol i just like that face tbh :D
( ͡° ͜ʖ ͡°)
( ͡° ͜ʖ ͡°)
It's usually meant to imply something sneaky/suggestive/lewd, you use it when making an adult joke. Thus the confusion, there's no sneaky big boy humor in your post so it just comes across as weird as fuck.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
13 hours ago, Micropoint said:
It makes you come out as pre-teen, but hey, if that's who you want to be...
You take life too seriously, fart one good time you will feel better after that.
Btw you are born in 1988 and still a student ?
Damn are you stuck in school ? ( ͡° ͜ʖ ͡°)
So between you and me, wh'os the teen now ?
LoL
LoL
I have masters degree in geology and mineralogy. Due lack of work in my expertise, I'm taking BA in engineering to get certified in GIS. Gives better chances of landing jobs. If you think age and education are tied like that, jokes on you. Get back to me when you're at same level, either with professional experience (5+ years) or with a degree.
Mineralogy ? ha thats interesting.
No i dont think age and education are tied it was just a joke buddy.
I have sold mineral for some years thats funny.
Mostly Moldavite including Labradorite. I am now into nuummite and high grade sugilite. ( ͡° ͜ʖ ͡°)
Dont be too serious, the day you gonna make the amount of monney i make per month come back to me too. :)
i have way more then your salary you make in one month in my hand on this pic. ( ͡° ͜ʖ ͡°)
We are all differents you decided to keep studying and its good, at 14 i decided to stop school and make my own monney and its good too.
High diploma are not always needed to make plenty of monney in life.
But i wish you good luck on your project for sure whatever you will do, open a mineral shop or travelling around the world and stuff like that. And if you find some high grade sugilite in sud africa ill buy them  ( ͡° ͜ʖ ͡°)
So dont judge people because you have higher diplome or whatever. Really. :)
And thanks for your help about these driver btw.
I don’t. I judge based on how people act and present themselves.
It still judging rofl.
i just like to use this smiley for fun not even for what it means, just get that. ( ͡° ͜ʖ ͡°)
Discussion over.
