repost to make it readable for others.
Any particular reason you're chosing intel over amd?
can you give us your expected use case. Primarily gaming or are you doing to do video editting on it?
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1093183-new-build-help/#findComment-12800881
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($198.90 @ OutletPC)
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard  ($153.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($84.99 @ Best Buy)
Storage: Patriot Burst 240 GB 2.5" Solid State Drive  ($33.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card  ($499.99 @ Best Buy)
Case: Cooler Master MasterBox MB510L ATX Mid Tower Case  ($48.98 @ Newegg)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1140.62
Generated by PCPartPicker 2019-08-12 07:37 EDT-0400
https://linustechtips.com/topic/1093183-new-build-help/#findComment-12800908
@m777y has provided a good similar build which currently will outperform the 9600 that you've chosen, simply because he made room to upgrade the 2060 to a 2070 super. Also, debatable i know, the 3600 will outperform the 9600k out of the box.
https://linustechtips.com/topic/1093183-new-build-help/#findComment-12800939
I'll recommend something like this instead...
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive  ($59.98 @ Amazon)
Storage: Hitachi Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($52.23 @ Amazon)
Video Card: PowerColor Radeon RX 5700 XT 8 GB Video Card  ($399.99 @ Amazon)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($89.99 @ Walmart)
Total: $1061.06
Generated by PCPartPicker 2019-08-12 12:32 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1093183-new-build-help/#findComment-12801591
