ryzen 3600 cooler
Go to solution Solved by TheBean,
for the 3600 the drp4 is wayyyyy overkill.
60-70c is perfectly normal. dont worry about it
so i have mine on my 3600 and its running high voltage but according to amd that's normal but my temps go to about 60 when gamiing and sometimes 70 which scares me a bit, but gaming isnt my concern rendering is a concern, should i buy a new cooler like the dark rock pro 4 and if so does it fit in the nzxt h500.
Also i dont know if ryzen master is telling me temps for all cores total so if someone could send me to a link to monitor all core temps that would be great
https://linustechtips.com/topic/1093002-ryzen-3600-cooler/
