1 minute ago, Taylor. W said:
Hello everyone,
I just finished a new build but I am having a problem. On my display I have flickering dots in a vertical line from the top of the screen to the bottom in a few spots. Does anyone know what is causing this?MVIMG_20190811_051821.thumb.jpg.5d67f30a087ff7e487fefed41ff342cd.jpg
Maybe try reseating the GPU or cleaning the GPU Pins with a Q-tip? Or make sure that the cable connecting the GPU to the monitor is properly connected and nothing is between it. Also, try different drivers if those dont work.
Setup No. 1: CPU: AMD Ryzen 2200g 3.95GHz GPU: EVGA GeForce GTX 780 3GB Dual FTW w/ EVGA ACX Cooler MOBO: MSI B350 Tomahawk Gaming Motherboard RAM: KingSpec DDR4 8GB Single Channel @ 2866MHz PSU: CS Series Modular CS 650M - 650 Watt Power Supply 80+ Gold Efficiency CASE: EVGA DG-73 STORAGE: 240GB Inland SSD, 320GB 7200 RPM Western Digital Hard Drive COOLER: Cooler Master ML240L - 240mm Liquid AIO MONITORS1x Dell 1920 x 1080p 24" Widescreen 60Hz, 1x Dell 1920 x 1080p 22" 60Hz KEYBOARDCheap Inland USB Keyboard MOUSE2400DPI Anker Gaming Mouse RGB CHAIR: Ikea MARKUS Office Chair
Setup No. 2: CPU: Intel i5-4950 GPU: Powercolor Red Devil RX 570 4GB VRAM MOBO: Asus B85 RAM: Ripjaws 8GB DDR3 @ 1333MHz Single Channel PSU: Insignia 450 Watt 80+ Efficiency Power Supply CASE: Thermaltake Versa N21 STORAGE: Samsung 860 EVO 240GB SSD COOLER: bequiet! Pure Rock Slim MONTIROS: 1x HP 24" 1680 x 1050p 60Hz KEYBOARD: Apple USB Keyboard MOUSE: Anywhere MX Logitech Mouse
I have tried reseating/cleaning the GPU, reseating the ram, changing HDMI cable and hooking the monitor up to a laptop. It isn't the cable or the monitor, so I'm wondering if the GPU is defective. It's an RTX 2060 paired with a Asus TUF B450-plus gaming motherboard.
Maybe try on another monitor? But if it's under warranty still I'd RMA it due to how much it is.
