Currently I have:
CPU: Ryzen 5 2400g
Motherboard: Gigabyte B450m DS3H
Ram: TEAMGROUP T-Force Delta RGB DDR4 16GB (2x8GB) 3000MHz
GPU: Sapphire R9 280x Vapor-x Tri-X
PSU: 550w 80+ bronze
Problem: system wont boot when I plug my gpu to the psu; only when IGPU is used i get a boot, but all fans and LEDs are on.
What I have tried, updated bios from f2 to f32, but im gonna go to 42b after im done writing and ill write an updated after if the system boots after updating. tried another slot but there is no spaces because of the front panel ports.
Im thinking that either the GPU is dead (which wouldnt make sense if the leds on the pcb is on, fans and led on the side.)  or the psu needs an upgrade to 650w
https://linustechtips.com/topic/1092379-help-upgraded-pc-now-gpu-wont-work/
It looks like probably the PSU is the issue (i hope).
Try your GPU on another system to check if it is really working.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Honestly, I would think the PSU Wouldn't be a problem because the minimum PSU requirements that are stated for your GPU is 550watt, which is what you have. I would most likely, if it's still under warranty don't, check if any capacitors or any high standing power delivery or tracers are knocked off, this could be the problem. I've had this before with a capacitor that had a loose solder point. Then again,  just be aware this is semi risky.
Setup No. 1: CPU: AMD Ryzen 2200g 3.95GHz GPU: EVGA GeForce GTX 780 3GB Dual FTW w/ EVGA ACX Cooler MOBO: MSI B350 Tomahawk Gaming Motherboard RAM: KingSpec DDR4 8GB Single Channel @ 2866MHz PSU: CS Series Modular CS 650M - 650 Watt Power Supply 80+ Gold Efficiency CASE: EVGA DG-73 STORAGE: 240GB Inland SSD, 320GB 7200 RPM Western Digital Hard Drive COOLER: Cooler Master ML240L - 240mm Liquid AIO MONITORS1x Dell 1920 x 1080p 24" Widescreen 60Hz, 1x Dell 1920 x 1080p 22" 60Hz KEYBOARDCheap Inland USB Keyboard MOUSE2400DPI Anker Gaming Mouse RGB CHAIR: Ikea MARKUS Office Chair
Setup No. 2: CPU: Intel i5-4950 GPU: Powercolor Red Devil RX 570 4GB VRAM MOBO: Asus B85 RAM: Ripjaws 8GB DDR3 @ 1333MHz Single Channel PSU: Insignia 450 Watt 80+ Efficiency Power Supply CASE: Thermaltake Versa N21 STORAGE: Samsung 860 EVO 240GB SSD COOLER: bequiet! Pure Rock Slim MONTIROS: 1x HP 24" 1680 x 1050p 60Hz KEYBOARD: Apple USB Keyboard MOUSE: Anywhere MX Logitech Mouse
I’m pretty sure it’s not under warranty so I’m gonna have to stick with buying a new one. Do you have any psu’s that you would recommend?
2 minutes ago, Saif alwahab said:
Do you have any psu’s that you’d recommend?
It depends on the budget mainly, but a good power supply would be for example a 650 corsair PSU or a 550watt PSU from SilverStone.
Also,try to aim for a PSU above bronze efficiency, I've had bronze power supplies make lots of noise.
My personal preference are the SEASONIC, grab  a 650W gold the Prime if you can afford it, or the focus, more of a budget one!
