Hello there! My name is Vydohr and I am pretty new to this forum but not the realm of Linus, his videos and his company. I have been planning on building myself a PC but a major problem I face is not knowing what exactly to get for what I want to do. I want to be able to run R6 Siege at atleast 60fps (This is my benchmark game as I play this the most) and I want to be able to build a computer to do so without breaking the bank. My budget is around $1000 USD, It would be greatly appreciated if I could receive tips on how to go about this.
I currently run a Lenovo Ideapad with an Intel Core i3 and 520 Integrated graphics, 6gb DDR3 ram.
Again thank you for the help.
-Your friendly Marine
https://linustechtips.com/topic/1091915-help/
Is that 1000$ including peripherals?
https://linustechtips.com/topic/1091915-help/#findComment-12791436
Just now, Vydohr said:
I'm slightly new to building PCs myself, If you could tell me what Peripherals are that would be much appreciated.
Monitor, keyboard, mouse, headphones, etc
Do you need those?
https://linustechtips.com/topic/1091915-help/#findComment-12791448
Do you need those?
I do not need any of those as I already have them.
To elaborate, Im not worried about how big the build is as I have ample amount of room for everything, I also am not to worried about going over 1k as my realistic budget is around my entire pension of 5000.
https://linustechtips.com/topic/1091915-help/#findComment-12791461
Gotcha. What type of display do you have? 1080p 60hz?
https://linustechtips.com/topic/1091915-help/#findComment-12791466
Samsung CHG90 Series 49-Inch Curved Gaming Monitor 1ms/144hz
Sweeeeet. Well this should do decently then:
https://linustechtips.com/topic/1091915-help/#findComment-12791512
5 minutes ago, Slottr said:
Thank you for the help. When I start building the PC Ill make sure to put it in the progress builds thingy. Again thank you greatly!
https://linustechtips.com/topic/1091915-help/#findComment-12791537
Just now, adman29 said:
Wait, are you going to be running it at a full 4K?
Not all the time. Probably only doing so with Netflix and maybe Siege honestly not sure
I mostly play console with my Xbox One X which I still call Scorpio. And that I always run full 4k but I run into overheating. So like I said, I do not think ill be running full 4k 24/7
https://linustechtips.com/topic/1091915-help/#findComment-12791558
1 minute ago, adman29 said:
Okay just wanted to make sure. I think the 5700 might be chugging at 4K. 1080 will get you letterboxing, but will run waaaaaay better.
I might upgrade it at a later point but aslong as I can run Siege at above 60fps instead of using my laptop on the lowest settings and barely getting 15fps, I think it will do
https://linustechtips.com/topic/1091915-help/#findComment-12791575
20 minutes ago, Slottr said:
There is Geil 2x8 3000mhz memory for $64 so why would you get this ??
And the lower CL latency will do absolutely nothing , for gaming or for most workstation application really. (check techpowerup zen 2 scaling)
22 minutes ago, Slottr said:
There,s sabrent rocket 500gb for $60 or tcsunbow X3 for $49. No idea why you chose that
23 minutes ago, Slottr said:
Bitfenix formula gold 550 , is $70 on newegg. And before you saw anything about the non modular , i,ll just say that the meshify C , having good cable management and a PSU shroud , will make modularity useless unless 1. the PSU is above 550W or 2. OP is doing cablemod , which he/she has not said so.
https://linustechtips.com/topic/1091915-help/#findComment-12791595
I do alot of cable management due to major OCD, Its a reason why I think I was chosen to be a Sniper in the Marines. Depending on what you mean by Cablemod I may be doing such, On most of my devices that involve cable work and management I get longer than needed ones to be able to say "Okay this works and I have room to spare" ect ect
https://linustechtips.com/topic/1091915-help/#findComment-12791607
this cablemod.
https://cablemod.com/
separately buying cables to fit a color scheme , you need full mod to do that.
https://linustechtips.com/topic/1091915-help/#findComment-12791609
I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($198.90 @ OutletPC)
Motherboard: MSI B450 Gaming Plus ATX AM4 Motherboard  ($84.99 @ Newegg)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($71.99 @ Newegg)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($59.89 @ OutletPC)
Storage: Hitachi Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($45.85 @ Amazon)
Video Card: ASRock Radeon RX 5700 XT 8 GB Video Card  ($389.99 @ B&H) Placeholder for AIB varient
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Amazon)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1010.59
Generated by PCPartPicker 2019-08-08 23:37 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1091915-help/#findComment-12792205
