I am needing some help in deciding what I should do regarding my build. I currently have a Ryzen 2700 OC to 3.5Ghz on all cores at 1.4V and am using a DeepCool Gamerstorm Captain 360 AIO with 3 Corsair ML 120 fans to cool it. I am currently idling around 40C but don't exceed 65C under a full synthetic load.
I know this is fine but would like to idle closer to 30C if possible or maybe push the clock a bit further.
I know it would look cooler (pardon the linus pun) to run an open loop but is there any real benefit that I would see due to the price? The most affordable kit i can find that has everything I need is the Thermaltake Pacific C360 at $299 on amazon.
Should I buy that or just stick with what I have?
I mostly game on my system but commonly do real work on it as well.
Full system specs:
Ryzen 2700 3.5Ghz @1.4V
Asus Prime X470-Pro Motherboard
32GB Corsair Dominator Platinum @3200Mhz
MSI RX 570 Armor MK2 8G OC x2
9.5T of mostly ssd storage.
https://linustechtips.com/topic/1091907-watercooling-help/
Whats your room temp?
Is the cpu downclocking while idling?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/1091907-watercooling-help/#findComment-12791403
