So like, since the first day i build my pc i always find out a slight amount of Input Lag in every game and especially eSport titles that's driving me crazy.
So when i move my Mouse i just idk feel a really slight amount of Input Lag and it doesn't feel 100% smooth as it should be, so i don't know how to fix it, i tried everything what i could find and myself knew about it and i don't know how to solve that problem in any way...
My System:
Ryzen 5 2600 / Ryzen 5 3600x
MSI RTX 2070 Gaming Z
MSI B450 Tomahawk
Cooler: Cooler Master ML120L RGB (120mm)
16GB Trident Z RGB Dual Channel 3000mhz
550Watt bequiet! Straigt Power 11
Monitor: Acer Predator XB241Hbmipr (180hz OC)
All Newest Drivers and newest BIOS Version
I would really appreciate someone who could may help :/
https://linustechtips.com/topic/1091472-input-lag-but-how/
it could still be forced on in the nvidia control panel but I don't think thats the default so maybe not that.
I've only ever noticed this issue before with vsync personally. Something else you can check is to see if the "enhance pointer precision" setting is on in windows but many people actually prefer the dynamic speed vs the 1:1 movement.
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788021
it's all set just right
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788032
1 minute ago, Votivee said:
Are you having the issues with the keyboard movement as well? If so then I'd suspect the monitor.
If it's only the mouse then try using a different one and see if you still have the issue.
i only feel it with mouse movement, and i tried out another one and it feels the same
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788058
1 minute ago, PatchyThePirate said:
yes
Maybe polling rate is the issue? Im not sure how polling rate works, so just a guess.
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788076
i tried that out too, no difference or even worse when going down with the polling rate
Aight then
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788088
You don't list the mouse.  Which one?
Have you tried other input devices?  Other mice?  Any lag with your keyboard, to rule out USB on the board/case?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788097
tried out another mice and other usb ports on the mobo
Mice: Razer Mamba Elite
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788109
what i did when this kind of stuff happened to me was, going to the properties of the game, then compatibility, and turning on admin mode, turning off fullscreen optimisation stuff, and running the game on windows service pack2, always did the trick, if it doesnt, try each of them individually, lemme know if it works
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788138
im not sure what you exactly mean but im sure this won't help or effect
https://linustechtips.com/topic/1091472-input-lag-but-how/#findComment-12788151
