Help with a pc overall update
Solved by Dedayog,
2 minutes ago, CoutoSH said:Right now I'm using the pc for games and streaming. I play in 1080p 144hz.
I was planing on updating the cpu this year and next one I'll update the GPU.
Then go with the 3700X + B450 Tomahawk + 3600MHz RAM (or 3000MHz depending on budget). Would be my recommendation.
