Cursed pc! pls help :(
Go to solution Solved by sniffsmurf,
Faulty motherboard
replaced it and the problemw as gone :)
I am becoming very desperate so i turned to the forum where i think the most competent pc users are!
specs:
GTX 1080 strix
ryzen 5 2600x - box cooler
Asus B450 f gaming MOBO
Corsair Vengeance lpx 16gb 3000mhz (8x2)
EVGA Supernova g3 650w +gold
Kingston SSDNow 120gb
Samsung 860 evo 500gb
Win 10 home
My problem is horrible frametimes...my pc works wonderfully for a while (sometimes almost a day, sometimes just 2 hours) and then i get these horrible, HORRIBLE frametime spikes. They cause big stutters that make every more demanding game unplayable. The games runs perfectly BEFORE this occurs.
Ive done pretty much anything:
reinstalled windows, updated bios, chipset drivers, SSD drivers
uninstalled gpu drivers with DDU and installing newest drivers atleast 4 times + trying older drivers
a bunch of different settings in both games and Nvidia CP and Nvidia inspector with V sync, pre-rendered frames etc.
disabling windows 10 settings such as the DVR thing and performance settings
Changing name on the GameBarPresenceWriter.exe program In windows to stop it from running
Switching out memory for another pair
Switching out to an identical gtx 1080
all this, to NO effect whatsoever. pls help!
https://linustechtips.com/topic/1090357-cursed-pc-pls-help/
windows 10 fresh install
Im a Aussie gamer on half decent hardware......
desktop
i7 7700k 4.8ghz Msi ProCarbon Z270 gtx 1080 250gb samsung 850 evo 16gb ddr4 3000mhz ram 2tb wd black 1tb wd green
laptop:
Msi gs40
i7 6700hq 16gb ddr4 gtx 970m 128gb ssd 1tb ssd
https://linustechtips.com/topic/1090357-cursed-pc-pls-help/#findComment-12778734
13 hours ago, vaiwalker said:
seems like a software issue. do a clean boot and see if it occurs
ok so the clean boot didnt do much. The stutter appeared after some hours of play.
Does anyone have any tips? any kind of diagnostics i can run and post the results?
https://linustechtips.com/topic/1090357-cursed-pc-pls-help/#findComment-12780520
Might be a PSU related issue.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1090357-cursed-pc-pls-help/#findComment-12780604
  • 1 month later...
