Hi!
Recently, I have noticed that my laptop has been extremely laggy and freezes sometimes, allowing me to move my mouse but not click on anything. I suspect that my computer has been infected by some form of malware and decided to do a fresh start. However, it is taking etremely long. Any idea what I should do?
https://linustechtips.com/topic/1090163-fresh-start/
Just now, r00tt00r said:
HP 14
Yes 128 GB
Windows 10
wich one exactly? There are manny models form this line.
But sure fresh install always helps. Did you backup important stuf?
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777212
It's like stuck on the
Getting things ready
This won't take long
And its taking forever
Windows update? Wait a bit longer and If nothing happens force shut it down and then try again
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777214
So yeah I put all my data here so that when this kind of things happen I don't have to back up my ssd
Yup
Ok just give it some time and if after like 1h nothing happens force it to shut down (hold power button) and then try again. If that aint helping reinstall Windows
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777225
Seems to me like the ssd is dying freezing mouse windows reset locking up
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777228
yeh, maybe. But could be a different hardware error or software related. Therefore first a reinstall
Oh and @r00tt00r plz check for BIOS update. Sometime this helps
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777232
I keep trying to reinstall WIndows but they keep telling me that an error happened and no changes were ade
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777313
ok, did you update BIOS and completely format the SSD?
https://linustechtips.com/topic/1090163-fresh-start/#findComment-12777314
