Dual Monitor Set-up
Leibow5
I am looking for another monitor to pair with my Asus VE248H. My budget is under $175 but I do not want to buy the VE248 because it is just a little to much. Any recommendations .
I hate ignoring what you said, but I highly suggest you get the same monitor. If you just don't have room for it or something, I understand.
You will really want identical monitors for dual monitor setups. Each monitor handles the picture so differently they will look weird.
As someone who has had multiple multi-monitor setups, and a current triple monitor setup, you should buy the same one.
