Weird Sound
Go to solution Solved by .Apex.,
2 minutes ago, Wraithsiege said:
(wear headphones so you can easily hear). While playing games, my pc produces this sound. It is not overheating. It only happens while gaming (if i pause a game it will stop and if unpause it will start). It only happens with my new gpu. Here is the sound
https://youtu.be/xuqmaWtJjzE
That's GPU Coil Whine, it's completely fine
https://linustechtips.com/topic/1089599-weird-sound/
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1089599-weird-sound/#findComment-12772737
29 minutes ago, Wraithsiege said:
Thanks mate, i was worried that it wasnt coil whine since all coil whine videos i could find on youtube had higher pitched coil whine
Which GPU do you have? This type of Coil Whine happens on the more recent GPU's, like the NVIDIA 10/11/20 series and AMD Vega/RX, which I think is a lot more annoying
https://linustechtips.com/topic/1089599-weird-sound/#findComment-12772881
