Hey @MrSpicedBacon
Nah, that's the maximum throughput the PSU can achieve (potentially). The wattage varies on how much power is required at a given time by the system. At idle it could use around 100 - 200 watts (depending on the hardware). Then, under load it will use for power (watts).
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/108940-psu-watt-consumption/#findComment-1455911
Then no
My 290X and i5 3570k uses 395w from the wall at 100% load.
Measured with a kil-a-watt meter. No overclock. So I agree with CoolBeans. He should be fine regardless.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/108940-psu-watt-consumption/#findComment-1455949
If it did draw 750w from the all 100% of the time while the computer only needing like 50wDC at idle, your PSU would essentially be wasting 700w as heat. Your computer's power consumption will varied depending on the usage of your computer, and it is not 100% constant. On idle, it likely well under 100w. During systematic loads of Prime95 and Furmark, you may see figures over 350w AC, while your typical load during a more realistic usage would be even lower than the figure than you see during Furmark and such.
https://linustechtips.com/topic/108940-psu-watt-consumption/#findComment-1456276
