So i've been cleaning up my setup a bit and decided to plug my Corsair Strafe RGB and M65 Pro into my monitor hub instead of straight to my pc so i can use a thinner, longer cable
The hub is USB 2 and the monitor is at least 12 years old. Would doing this add any latency? I haven't noticed any so far and my mouse hasn't had an issue maintaining a 1000hz 1ms pulling rate.
https://linustechtips.com/topic/1089357-usb-hub-adding-latency/
in theory yes, in practice it's fine as long as you dont notice anything
Desktop benching:
https://linustechtips.com/topic/1089357-usb-hub-adding-latency/#findComment-12770768
