Okay I need to build an Editing, Rendering and Streaming Rig!
I want it to be an Intel build and preferably a hex core one at that!
I need an OS and the case doesn't bother me but I want an efficient power supply if possible please!
ANY HELP WILL BE GREAT!
Budget: £700
https://linustechtips.com/topic/108924-editing-build-help/
there are intel processors worth more than your whole budget "/
you need to go on the amd route
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455718
yep, better look at the prices of those hexacores alone
CPU: 3570k @ 4.8Ghz MB: Gigabyte Z77-UD5H GPU: GTX 1060 PSU: BeQuiet PP 630W OS: Mac OSX & W10 Ram: Corsair Vengeance Low Profile 16gb 1600mhz Storage: 1x Samsung 860 EVO 1TB; 1x Samsung 850 evo 250GB  Case: Fractal Design Define R4 Audio: Fiio E10 & Sennheiser HD558 Display: Eizo FS2333
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455744
Hexacore + Intel = Double your budget.
If you want cores, you're going to have to go with AMD.
Well what's the cheapest hex core intel build? Xeon maybe!
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455764
so... this is the cheapest intel hexa* core cpu : http://uk.pcpartpicker.com/part/intel-cpu-bx80633i74930k
if you get than, you won't have enough money for anything else "/
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455813
What about a complete build with it?
in your budget: no
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455893
Yeah but what would be the cheapest?
don't build a crappy pc around such a CPU, rather get a slower CPU and mybe include a SSD. You'll enjoy your pc much more
https://linustechtips.com/topic/108924-editing-build-help/#findComment-1455947
