It depends on the router/brand, with some you can and with some you can't. Check out the specifications and if it doesn't say anything about it, it probably can't.
Well, i tried googling to try and find the answer but the more i read the more confuse i get. hahaha
thats why i decided to post here and ask rather than googling for it.
Btw, the brand of the AP is TP Link TL-WA901ND and the router is D-link DIR 615.
Thanks =)
Thanks =)
I just looked and apparently, it does support it (check http://www.tp-link.us/resources/simulator/TL-WA901ND_V3/Index.htm).
 Thanks!
is this the one?
Bridge with AP - In Bridge with AP mode, this device can be used to combine multiple local networks in distant hard-to-wire distant together to the same one via wireless connections. While bridging with other APs, this device can also act as an access point at the same time to create a local wireless network for all Wi-Fi devices.
 Thanks!
is this the one?
You want the Repeater(Range Extender) option, otherwise you will have 2 separate networks.
