So all of a sudden DOCP profile will not boot and forces me to do a bios reset. It will boot if manually set to 2933Mhz and It will boot anything past 3000Mhz up to 3200Mhz. It just won't boot with DOCP enabled or 3000Mhz set manually with timings set manually. So i am very puzzled what is going on.
I have ran Memtest overnight saturating all unused memory with no errors.
I have reseated and swapped slots same result.
BIOS is up to date and have also flash the up to date bios just to rule it out.
Currently it will run 3200Mhz at DOCP timings and voltage.
The kit is https://www.newegg.com/corsair-16gb-288-pin-ddr4-sdram/p/N82E16820236426?Item=N82E16820236426
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1088868-memory-issue-wont-boot-3000mhz/
