streaming G4400 for streaming pc build
Solved by JCP,
1 minute ago, Mazin said:I used all of my funds on upgrading the gaming pc... I’ve just got enough to buy a g4400 I was just wondering if that processor would be able to handle streaming at the lowest possible settings at 720p
Yeah, you probably wanting him to reply aswell but i'm just gonna add, i was able to use the ndi plugin to stream at 720p 60fps when using the pentium g4560 (2 cores, 4 threads) and a celeron g3930 (2 cores, 2 threads). I lost my celeron machine to a power surge but it worked well
