So this is my PC set up:
I bought the GPU from eBay and it was listed as a used mining card. When I received it, there wasn't anything that seemed off about the card. The card works under regular load. I can play Black Ops 4, OverWatch, and Battlefield fine with my temperatures below 80C but from time to time if the computer is loading something for a while, the display would shut off and my monitor would tell me that there is nothing connected. Like I would open Premiere Pro, Photoshop, and Discord at about the same time but then my display would go out. Or if I run Cinnebench 20 more than 1 time. Is there anyway I can reset my GPU settings?
https://linustechtips.com/topic/1088068-random-display-issues/
