New case or water cooling ?
Solved by seon123,
Check the settings for any protections in the BIOS, and also adjust the fan curve.
There is no "normal" CPU or GPU temperature for you to compare against. That depends on the CPU itself (even within the same model), the cooler and case, and the motherboard. For the GPU it also depends on the GPU itself, the cooler and the case.
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting1 -
2
4
ken43 ·
Posted in Troubleshooting5 -
5
thedood2k ·
Posted in Power Supplies3 -
2
DARTHDIVIDER0213 ·
Posted in Troubleshooting8
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
