RAM speed problem
Go to solution Solved by Dxer,
What program are you using to see the ram speed?
Typically you would multiply that reading by two.  So, if it says 1600, then it is running at 3200.
I noticed my RAM was only showing at 1533 or sometimes 1600, despite being rated at 3200. I'm running the AMD Ryzen 2700 on an MSI X470 Gaming Plus motherboard with an RTX 2070. I've gone into the BIOS and enabled XMP Profile 1 already and even changed the manual override to 3200. It's still showing the same 1533. I'm wondering if it has something to do with the timing or I'm maybe missing something. Any help would be appreciated.
https://linustechtips.com/topic/1086940-ram-speed-problem/
Yeah that's fine, the monitoring stuff will always show you the half, because memory works in double blah blah you can google it if you'd like...
1600x2 = 3200 it's running as advertised.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1086940-ram-speed-problem/#findComment-12753426
CPU:   Ryzen 7  5800x      CPU Cooler: Corsair H115i Pro       Motherboard:  Asus x570 TUF Plus      Memory:  64GB Corsair Vengeance DDR4-3600
GPU:  ASUS TUF RTX3080        SSD: Crucial P5 1TB  PCIe NVMe  Samsung 990 Pro 2TB           PSU: Corsair CX750       Case: Thermaltake View 71 TG RGB
Monitors: LG 34" Ultrawide    Samsung 28" 4k
https://linustechtips.com/topic/1086940-ram-speed-problem/#findComment-12753430
