Hello all
So i have a dual system build in the near future in the Corsair obsidian 1000D
I am wanting to cool a 9900k - 2080ti & 2700x - gtx 980 on a single loop.
How would you go about cooling this?
how many rad? what size? what kind of res and pump?  loop order ect..
All suggestions are welcome even if it comes to just using two custom loops.
Thank you for reading.
https://linustechtips.com/topic/1086268-dual-system-loop/
40 minutes ago, TheLividTurnip said:
Hello all
It is possible yes, but not recommended, as @emosun said: you would need to disassemble both systems in order to perform maintenance on one. Another issue is if the main system powers off for some reason the second system could overheat due to the pump being shut off with the main system.  I would recommend probably a 240 rad for each system is the bare minimum, probably would suggest a 360 for each with some high static pressure fans. Loop order and res really doesn't make a difference for performance, any D5 pump (they are rebranded by many brands, EK's pump/res combos are always a safe bet.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1086268-dual-system-loop/#findComment-12748856
