I am building ( or getting built ) a new pc to use for streaming / gaming ( esports titles as I am part of a team and am wondering if getting a cpu ( ryzen because I’m livin that cheap life ) with a higher base / boost clock will be better or the same as something better but with lower clock speeds. In my case I am looking at a ryzen 3 2300x vs something like a ryzen 5. My thinking is that the 2070 that will be in the system and the factory over clocking ( 10% ) will offset the the corners cut in the cpu dept. If that is wrong please tell me and if anyone has a powerful prebuilt with a 2070 for a good price please leave a link for me. Thank you for all of the help!
https://linustechtips.com/topic/1086189-need-help-with-cpu-selection-on-new-pc/
1. Dont buy a prebuilt
2. For a 2070, get a ryzen 5 3600 to match that and give you more time before you need to upgrade
Desktop: Slick
CPU: Ryzen 5 2600    Motherboard: Asus Prime X470-Pro    RAM: 16GB Corsair Vengeance LPX 3200mhz CL16   GPU: GTX 1080 8GB
Storage: Samsung PM981 256GB (970 EVO)    PSU: Corsair TX650M   Case: Lian-Li PCO11 Dynamic - White  Fans: Deepcool RF120mm RGB
Peripherals: HP Omen X 35 Ultrawide (3440x1440, 100hz, G-Sync), Logitech g903, mdr-1000x, umc22 + AKG D5, Drevo Blademaster 87K RGB (Gateron Browns)
Laptop: Surface Laptop 2 Platinum - i5 8250u, 8gb ram, 256gb nvme, 13 inch pixelsense touch display
Phone: Huawei Mate 20 pro 128gb Black + iphone 6s 32gb gold
basically what @Zeddex said
if you can afford it get a R5 3600. it will be better for gaming than similar priced 2000 series Chips IMO
I recently built a System with a 3600 and a 2070 and can't complain.
got a msi armor, so basically the cheapest offering (non A chip) and was able to OC it to 1980 MHz on the core and 2000 MHz on the Memory stable.
resulted in a sweet 9000+ TimeSpy score
https://www.3dmark.com/3dm/37948984
also you can consider bying used if you are ok with it.
b450 and x470 boards (those will Need a bios update!) are widely available as are used RTX cards
i bought everything exept cpu and ram for my used and had no Problem what so ever.
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
