Hey guys!
So last night i launch Origin to Play Apex
And from yesterday i am looking searching for a solution but nothing.
Here is a picture
Any help will be appreciated.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1085951-origine-issue/
20 minutes ago, Constantin said:
Hey guys! So last night i launch Origin to Play Apex And from yesterday i am looking searching for a solution but nothing. Here is a picture Any help will be appreciated.
Give it a day or two at most and everything will have fixed itself.
https://linustechtips.com/topic/1085951-origine-issue/#findComment-12746241
Ok,So the weird think is that i live in Greece, if i synchronize the clock with Internet time, it show it wrong (it's 15:00 and the clock after the setting show 14:00), Origin wont work, if i manually set the correct time, origin work just fine.
Can anyone explain to me what is going on?
https://linustechtips.com/topic/1085951-origine-issue/#findComment-12748888
