Best white coolant that glows with rgb lights
Solved by W-L,
14 minutes ago, LordElites said:What would be the best white colored coolant that glows with rgb lights?
Mayhems or EKWB's pastel lines are good options as any white opaque coolant will reflect the RGB lighting, not glow per say. If you want your coolant to actually glow there are UV types and using the appropriate UV lighting will give you a glow effect.
