Goal is to Play New and older games on mid to lol end up to 1080p
Specs
PCPartPicker Part List
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($79.89 @ OutletPC)
Motherboard: Asus PRIME A320M-K Micro ATX AM4 Motherboard  ($60.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory  ($67.89 @ OutletPC)
Storage: Kingston A400 120 GB 2.5" Solid State Drive  ($19.99 @ Amazon)
Power Supply: HEC 200 W Mini ITX Power Supply
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($54.90 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($105.89 @ OutletPC)
Total: $389.55
Generated by PCPartPicker 2019-07-23 08:18 EDT-0400
Suggestions?
Pc part picker thinks it Will keep under 200w
Case is undecided atm
https://linustechtips.com/topic/1085438-ryzen-build-planned/
Get any b350 motherboard instead of that junk.
Also asrock b450m pro4 should be 75$, so just get that instead, but if that is too expensive, then get a b350 board.
Also you could get ddr4 3000mhz memory for the same price, so don't get 2400mhz, especially if you plan to use the apu.
And also the r3 3200g costs the same, so i would get that.
I only see your reply if you @ me.
https://linustechtips.com/topic/1085438-ryzen-build-planned/#findComment-12742320
There's no price listed for that PSU, so that's going to bring your total up. Also that thing is probably junk. Leaves you with zero room for expansion as well.
EDIT: Do you really need a $55 blu-ray player? That's the price of a decent PSU for your wattage.
~Air Cooling Advocate~
https://linustechtips.com/topic/1085438-ryzen-build-planned/#findComment-12742378
Good suggestions
Hov Will the game performance be if I Kept the A320 mobo and the 2400 MHz ram?
Thing is that I already have those ram Sticks in storage and I have Zero plans to overclock plus I Wanna use the stock cooler
For expansion I might just buy an additional system when I want to use a graphics card
I might not need a Blu-ray drive I guess
Plus I already have a system with a GTX1080Ti as well
And the r3 3200g is more expensive for me to buy Than the r3 2200g
https://linustechtips.com/topic/1085438-ryzen-build-planned/#findComment-12742577
