PLEASE HELP! Audio Editing
Hi, so I just recorded some gamemeplay, and the in-game sounds are so much louder than my voice. I would like to either make the in-game sounds either quieter or mute them completely. Is there any free software that I can use to edit my video like this?
>Cheers!< Jrv01
Keep posting guys!
https://linustechtips.com/topic/108526-please-help-audio-editing/
not if they on the same track... this is why people use programs such as Dxtory cause you can have separate tracks for the audio when recording game play.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
Well I used nVidia Shadowplay to do this... So...
>Cheers!< Jrv01
Keep posting guys!
>Cheers!< Jrv01
then no :L shadow play puts them all onto one track and this is why i don't use it to record with cause that happens even with Vegas it can't be done . sorry mate :/
Sparky
Current Build :
Laptop:
 CPU:
Please help me guys! I have to solve this problem!
>Cheers!< Jrv01
as i said before re record it using Dxtory then problem solved :) or just rerecord your voice in Audacity and overlay it as a second track and make the track on the video the game-play :)
Current Build :
Laptop:
 CPU:
you cant solve it, if you already recorded it, you cant seperate it into 2 tracks for each.
Use Dxtory next time and then itll record into different streams, also when you do, Sony Vegas wont see them, so you ll need to use a program like Adobe premiere or audacity
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
