So I'm going on a vacation in a little bit and want to buy a laptop. This laptop needs to be able to run roblox at 60 fps on 720p and be able to record that way. I'm okay with a used laptop. My budget is 150 dollars, but want the lowest price possible. I also would like to be able to run fortnite at 30+ fps on low 720p (no recording) and have 8gb of ram for multitasking purposes, as this will be the laptop I will be using for school too.
https://linustechtips.com/topic/1085253-laptop-help-please/
Yeah, I don't know what laptop to get you, but I suggest you take a look in the great deals section.
Link to hot deals: https://linustechtips.com/main/forum/69-hot-deals/
https://linustechtips.com/topic/1085253-laptop-help-please/#findComment-12741102
visit some local pawn shops, if they're not greedy fuck faces they'll give you a good deal.
I haggled and traded about $100 worth of stuff for an Inspiron 15 Gaming 7567 with an i5 7300HQ and 1050 Ti.
Sorry about my spelling sometimes. My $1200 laptop has a $2 keyboard.
https://linustechtips.com/topic/1085253-laptop-help-please/#findComment-12741299
