They are all ddr4, that's what the 3900x supports. 3200 MHz won't make a difference to the average user compared to 3000 MHz.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740720
I am going to be using this pc for video editing so wanted the best ram possible. So is the 3rd option ddr4 ram? Could the 3900x support less?
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740729
Yes, the third option is DDR4. As far as I know, the 3900x can support anything from 2133 MHz to 3200 MHz ram. Compatibility for ram capacity depends on the maximum amount of ram your motherboard/cpu supports.
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740742
3 minutes ago, TrainFan2019 said:
Yes, the third option is DDR4. If I'm not mistaken, the 3900x can support anything from 2133 MHz to 3200 MHz ram. Compatibility for ram capacity depends on the maximum amount of ram your motherboard supports.
Okay the motherboard is a micro atx b450 motherboard. Asking as the 3rd option is ddr4 then it’s fine
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740759
Option 3 is fine.
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740771
19 minutes ago, lee32uk said:
Yeah but that website/store is based in the USA.
Ffs, just went to pay for it and it went from 1380 to over 2000 for taxes and stuff. I was so happy with that build. Do you know any websites in the uk that can make a good build? I’ll
https://linustechtips.com/topic/1085212-ram-help/#findComment-12740860
Overclockers UK, Scan, Aria and Gladiator pc. You don't want to build your own though ?
https://www.overclockers.co.uk/
https://www.scan.co.uk/
https://www.aria.co.uk/
https://www.gladiatorpc.co.uk/
https://linustechtips.com/topic/1085212-ram-help/#findComment-12741179
Well I may build my own I’m not sure yet. But if I can find a decent deal and have it made for me I’ll do that
https://linustechtips.com/topic/1085212-ram-help/#findComment-12742264
