Hi everyone. I'm planning my first build.
My current PC (Core i7-4790K + GeForce GTX 970) is 4 years old and it struggles a little bit when the population in game (Cities: Skylines) grows past a certain point. Also The acceleration of 2x and 4x is essentially the same as 1x. I'm in need of a more powerful setup.
The budget is €2500. Most likely I'll buy from European Amazon sites, since the offers from my local Finnish retailers are usually overpriced.
I'll keep using my old monitor (1440p) and peripherals.
PCPartPicker Part List
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  (€489.00 @ Caseking)
CPU Cooler: Noctua - NH-U14S 82.52 CFM CPU Cooler  (€69.89 @ Aquatuning)
Motherboard: Asus - ROG STRIX Z390-F GAMING ATX LGA1151 Motherboard  (€209.90 @ ARLT)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 Memory  (€166.92 @ Amazon Deutschland)
Storage: Samsung - 970 Evo Plus 250 GB M.2-2280 Solid State Drive  (€74.98 @ Amazon Deutschland)
Video Card: Asus - GeForce RTX 2080 Ti 11 GB ROG Strix Gaming OC Video Card  (€1249.00 @ Alternate)
Case: NZXT - H500 ATX Mid Tower Case  (€79.90 @ Caseking)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€99.90 @ Amazon Deutschland)
Total: €2439.49
Generated by PCPartPicker 2019-07-22 15:33 CEST+0200
(I picked a 250GB SSD on purpose. Storage capacity isn't going to be an issue.)
Thanks for comments and suggestions.
Edited by whatUwant
https://linustechtips.com/topic/1085077-my-first-build-plan/
As you will be using it for gaming only and the i9 9900k is the best option you have, I would stick with this build personally.
Your CPU alternative is Ryzen 9 3900x which is ever so slightly behind on gaming performance but obviously has the core count advantage so if you plan on any productivity workloads in the future, I would consider getting the 3900x.
That is really the only point worth mentioning here as every other part of the list is fine.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739529
Thanks.
Ryzen 3900 was under consideration but the game doesn't seem to be able to utilize all the threads (or so I've heard).
My main concern was motherboard & cooler. I don't know if they work well with other components, or if I can get better deal by choosing cheaper alternatives.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739543
Since i play skylines quite often, and don't experience the issues you are facing i'm wondering how much ram you have in your current machine?
Sure the cpu is a bit older, but its not absolete and should be able to run skylines with quite a few mods.
I am running a ryzen 1700 with 32gb of memory and a GTX 1080 and have no issues with skylines.
on topic.
I think if you're playing skylines and games like that, than the 2080TI might be a bit overkill.
Getting a 2080 (super) alone could save you 4 - 500 euro. Which you could spend elsewhere.
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739571
Glad to hear from a C:S player! Thanks for the suggestion.
Currently the RAM capacity is 16GB.
IIRC CPU was quite busy during game. Task manager indicated usage close to 100%.
What's your population?
I thought about going for 2080 super too. Its VRAM capacity is only 8GB. Will it be a problem?
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739619
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739628
OP, I would stay with your current build but get a 2080 super instead. It's much cheaper, and 8gb of Vram really won't be an issue. Also get a gigabyte aorus pro mother board, those are really good motherboards compared to others. And though the h500 is a great case, it is known to have mediocre airflow, so please keep that in mind.
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739666
Why when you can get far better value for money with Ryzen ?
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739681
I do agree with you, but my reasoning was that the OP said his build was mainly for gaming. Ofc ryzen has better value, but it's up to him whether.he wants to do that.
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739689
The only advantage with Intel is at 1080p high refresh rate gaming. At 1440p/4K there is less of a gap (Virtually none at 4K). As he mentioned playing Cities Skylines then you don't need 144fps for that game anyway. Hopefully the op has more than a 1080p screen if considering a 2080 Super or 2080 ti.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739701
58 minutes ago, lee32uk said:
Hmm I never really considered AMD. But their reviews are quite positive. It looks promising. Thanks for the suggestion.
I have a 1440p display.
I didn't know about the airflow issue. Thanks for pointing that out!
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12739780
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12740155
16 minutes ago, whatUwant said:
Stick with the 8 core if you are just gaming.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12740237
Obviously this varies per game, but top game i have about 1,8mil pop.
Vram shouldn't be an issue, Vram only gets to be an issue at higher resolutions, and then i'm talking about 4k. 2080 super should be just fine at 1440. (or beta / early acces games with little optimization).
As stated above, Ryzen is a good alternative. Yes it is still a little less powerfull in terms of gaming compared to intell according to multiple benchmarks, but the price premium in my eyes is not worth going intel. This is however more of a personal choice currently. It is however more likely for AMD to continue the AM4 socket than it is for intel to continue their current socket over to their next generation chips.(likely, not guaranteed).
If going for a ryzen and only using the system for gaming, i would opt for a X470 board and not a X570. Once again in terms of pricing, the X470's generally offer more features at lower cost than the X570, and the benefits of having a X570 aren't needed for gaming. If you would do rendering and other workloads that require high throughput on disk drives it would be a logical choice.
I would suggest the following setup, in this i've chosen a 3700x because the 3800x doesn't offer much more for the price addition. the 3900x is a bit overkill on cores as most games won't utilize this (for now) and disabling 4 cores to benefit from the added cache it offers will be an enthusiast thing.
I have chosen 2 kits of 2x8 simply because i couldn't find a 32 kit. And these should be B-Die chips.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12741796
14 hours ago, whatUwant said:
Go with this, you wouldn't regret...
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€349.00 @ Alternate)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  (€231.42 @ Amazon Deutschland)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory  (€97.89 @ Alternate)
Storage: Intel 660p Series 1.02 TB M.2-2280 Solid State Drive  (€105.84 @ Mindfactory)
Video Card: Sapphire Radeon RX 5700 XT 8 GB Video Card  (€419.00 @ ARLT)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€84.90 @ Caseking)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (€79.99 @ Corsair DE)
Total: €1368.04
Generated by PCPartPicker 2019-07-23 09:58 CEST+0200
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12741869
1 hour ago, Caennanu said:
Thanks.
I did the calculation again with prices from local retailers:
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor €349.00 @ Gigantti
CPU Cooler be quiet! Dark Rock 4 CPU Cooler €69.00 @ Mikromafia
Motherboard Asus ROG STRIX X470-F Gaming ATX AM4 Motherboard €218.00 @ Tietokonekauppa
Memory G.Skill Flare X 16 GB (2 x 8 GB) DDR4-3200 Memory €125.74 @ Proshop
Video Card Gigabyte GeForce RTX 2080 8 GB WINDFORCE Video Card €686.99 @ Amazon Deutschland
Case Fractal Design Meshify S2 ATX Mid Tower Case €135.99 @ Amazon Deutschland
Power Supply EVGA SuperNOVA G3 550 W 80+ Gold Certified Fully Modular ATX Power Supply €111.95 @ CDON
  Total (w/o shipping) €1822.41
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12741878
Either of those builds will last you for 5+ years, providing you take care of the system.  The only upgrade I'd suggest is, to opt for a platinum rated power supply (and maybe increase the W to 700+, because you can).
Then, take care of your system:
- Monitor and sustain decent thermal performance, which is especially important if you overclock your CPU
- Re-apply thermal paste on a reoccurring basis
- Clean the case of dust and grime
- Remind yourself of how fortunate you are
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12741937
I don't see the point of going with an X470 board if you are paying that much for one, when an entry level X570 isn't much more. Also that board would need a bios update to run that cpu. It makes more sense to go B450 if you are wanting a cheaper option than X570, and even then it isn't a smooth process even with bios flashback on something like a Tomahawk board.
You don't need to buy expensive B die ram when you can get E die for a lot less, like the Crucial kit in my spec.
That psu has protection issues.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12742131
See my post above.
Total: €1368.04
How about this one??
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12742145
No build is perfect, thats why we suggest things. Chose B-die simply from a quality / compatibility standpoint. It is a first build afterall
-- edit --> and yes flashing the bios could be an issue considering its a first build. So yeah, an X5 series might be the better option in terms of ease of installation.
If that PSU has protection issues, i'm surprised as i picked it from the psu tier list under budget (tier B)
7 minutes ago, whatUwant said:
Not sure if it's a mistake, but my local retailers have Asus ROG STRIX X470-F Gaming ATX AM4 Motherboard priced at €218 and Gigabyte - X570 GAMING X ATX AM4 Motherboard at €199. Seems like a no-brainer here.
That would seem as a nobrainer indeed. But when checking the following list, you will notice that the X570 board needs additional cooling or is borderline on the VRM's for overclocking a 3950x when it comes out, where the X470 wouldn't need that. So that entails the VRM's are stronger on the X470 than the X570.
In your case it wouldn't be an issue, with a 3700x, but it could limit your choices in the future if you want to grab a 2nd hand to lengthen your system's lifetime a bit
https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview
-- edit
The price difference between local retailers and pc part picker is indeed quite big. i cannot account for that unfortunately.
https://linustechtips.com/topic/1085077-my-first-build-plan/#findComment-12742157
