So, I've been using HIDMacros to help me with my writing, making it a bit easier to hit the bold, italics, and underline hotkeys easier instead of doing finger yoga to reach the ctrl and letter keys.
And since then, I've been thinking about using a second mouse to simulate clicks like "Ctrl+leftclick" (which opens up a new tab) and "Ctrl+righclick" (which opens a new window) however, the problem I'm facing is what the script is supposed to be for doing this kind of combination.
I'm not good at scripting, so any help is really appreciated.
Thank you in advanced.
https://linustechtips.com/topic/1084854-a-script-for-my-mouse/
This program is great if you have extra keys on your mouse. You can assign a key to do a combination of other keys. If you're looking to use your keyboard keys as macros then use Macro Recorder.
Mouse: https://www.highrez.co.uk/downloads/XMouseButtonControl.htm
Keyboard: https://www.jitbit.com/macro-recorder/
https://linustechtips.com/topic/1084854-a-script-for-my-mouse/#findComment-12738123
