NZXT P120 fan
KHFGL
Hi,
I'm gonna buy a Kraken X52 for my R7 2700x.
My case is a Sharkoon TG5, so i gonna buy a plus fan. (cooler will be mounted to the front)
The kraken have NZXT Aer P120 fan, so i want buy a P120.
Can i install it to the case? I mean the screw hole match/standard?
I'm asking it because there is a Aer F120 fan, and i think the screw hole of the 2 is different in the picture. But maybe just in the picture.
I searched a stock picture of both P120 and F120 in chrome and switched tabs.
(I don't want to buy kraken X72, much expensiver here)
Edit: maybe i should have to post to liquid cooling section, sorry.
Yes, you can install it. The screw holes are the same.
