Hello people, I need a little help with my gpu fan. Specifically, where to get a new one. I have a gtx 1060 6gb Msi Mini graphics card, and its fan has recently stopped working. I've been searching the internet for a new fan, and apparently, they are more scarce than a 7nm Intel chip. I can't seem to find the specific fan that would fit my graphics card, and I don't know if there are any other branded ones that will. I need help with either finding a new one, or figuring out if I can fix the old one. It doesn't seem like it has any physical issues, it simply won't spin. I'm kind of a novice when it comes to computer repair, so any help would be welcome!
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/
GPU fans don't spin until it's necessary. Do you play games with your card?
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12735871
Sorry about my spelling sometimes. My $1200 laptop has a $2 keyboard.
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12735879
Yes indeedly I do! The only reason I noticed/looked into it is because my temps were getting in the high 80s on overwatch, a non gpu bound game. If I keep vsync enabled, it stays below 60, but I really don't like playing fps with vsync enabled because it adds lag
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12735905
download this program https://www.techpowerup.com/gpuz/
then click the highlighted option and click the button. Then click the senor tab and watch the if the fan RPM starts going up. (usually around 55/60 C)
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12735917
Update to the problem: I'm using GPU z and while gaming the fans don't spin. I'm getting to 80+ degrees. The software seems to recognize the gpu and it says the it's running at 0 rpm at full load. Do I need to get a replacement fan, or could it be some sort of software issue? PS. I've also cleared out the heatsink and PC of any dust that could be stopping/impairing it.
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12757766
@Kylixion
Which SPECIFIC MSI GTX 1060 6GB model do you have?
MSi offers...four different single-fan GTX 1060 6GBs, and they use different cooling fans.
As to where to get a hold of a replacement fan, your best bet is on eBay.
For example:
https://www.ebay.com/itm/New-MSI-RX560-GTX1050-1060-AERO-ITX-Graphics-card-fan-HA9010H12SF-Z/183816674358?hash=item2acc53dc36:g:fE0AAOSwIilc4M~l
https://www.ebay.com/itm/85mm-MSI-GTX1060-P106-Dual-Fan-Replacement-40mm-4Pin-HA9010H12F-Z-12V-0-57A-R220/183183391921?hash=item2aa694bcb1:g:JvcAAOSwZBha1hvL
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1084566-gpu-fan-issues-help/#findComment-12758133
