A few days ago I was streaming on twitch playing apex legends in 720p 60fps on obs. Today my obs were telling me I had an encoding overload which never happen before. I did an auto configuration on obs and it is telling me that it can only do 480p at 30 fps. I went on streamlabs obs to see if it might be obs having issues, but streamlabs is telling me the same thing. I have a vega 64 gpu and a ryzen 5 1600 CPU and been streaming with it for months. I once had the same CPU with a 1060 3gb and can stream at 720p 60fps on siege. I don't know if it is a hardware issue or what. Anyone has any suggestions?
my specs
Operating System - Windows 10 Pro 64-bit
CPU - AMD Ryzen 5 1600 6 cores/12 threads
RAM - G.SKILL Aegis 16GB (2 x 8GB)DDR4 DDR4 3000
Motherboard - Gigabyte AB350-Gaming 3-CF (AM4)
Graphics - Radeon RX Vega 64 8gb
Storage - 2TB Seagate ST2000DX001-1NS164 HDD
                250GB KINGSTON SV300S37A240G SSD
https://linustechtips.com/topic/1084305-ryzen-5-1600-obs-issues/
my specs
I'm not entirely sure but it might just be an OBS update or issue causing trouble for all we know... Unless you've been tinkering with the settings, BIOS options, or the hardware itself, then this shouldn't be happening. So it might be software related...
CPU: AMD Ryzen 7 2700X; GPU: MSI RTX 2060 Gaming Z; MoBo: MSI B450 Gaming Plus ATX; RAM: TForce Delta TUF RGB 3200MHz (2x8) 16GB;
Case: CoolerMaster MB511 RGB TG; PSU: Seasonic Prime FX Gold 750W Fully Modular; CPU Cooling: Cooler Master MA620P; Storage: WD Blue 250GB SATA SSD & Seagate Barracuda 2TB 7200RPM; Monitor: MSI MAG241C 144Hz Curved Gaming Panel; Keyboard: Corsair K95 RGB Platinum (MX Brown); Mouse: Fantech X11 Daredevil
