Im putting in my rtx 2080 ti and i dont know how i should have it cabled.
The first picture is with one cable with all of the connections and the second picture is using 2 cables with the other cables hidden behind
ive heard that if u only use 1 cable it can get too hot or something, can anyone help?
https://linustechtips.com/topic/1083912-i-need-help/
Honestly you can go either way.  It will draw the power and the ampage on the 12v rail is what matters.  Both will use the PSU correctly and your card will run fine.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731221
Just now, arvid_haland said:
what would you do?
Well Id say pic 1 because it is less clutter and neater basically.  But pic 2 is neat too the cable goes out the side of the case ,, I mean its a bit different look,, Go with how you want it to look thru your tempered glass.
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731242
Ok, thank you so much for the help man, appreciate i :D
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731246
My pleasure my friend.. Anything else you can post thread or private message me.  :)
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731251
I know my HX850 manual says that when using a 2 plug GPU to ensure to use two different PCIe power cables, and to not mix modular with non modular (for crossfire).
Use both cables, not to say it WONT work with just 1, but your PSU has two separate ones for a reason (and my PSU has 4 for SLI/Xfire)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731253
Yes your right for about Crossfire or SLI.  Also I think hes modular, so even better and neater
https://linustechtips.com/topic/1083912-i-need-help/#findComment-12731263
