HELP MOBO
Go to solution Solved by CrazieChipmunk,
Ok everyone so as it turns out i was being really dumb all i had to do was press the button again. sorry for wasting your time
Dont use all caps please.
What do you mean RED LIGHT?
https://linustechtips.com/topic/1083810-help-mobo/#findComment-12730351
Just now, CrazieChipmunk said:
like when you press the flash bios button its meant to flash alot but mines not it flashed i think and now its staying still
Does your pc boot?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1083810-help-mobo/#findComment-12730365
I don't have a MSI board, so i cannot comment on the bios flashing.
https://linustechtips.com/topic/1083810-help-mobo/#findComment-12730367
2 minutes ago, CrazieChipmunk said:
It said to not do anything until flashing light is off but my problem is, is that its not flashing
Switch it all off, and try the flash again. Sure the stick is correctly formatted with the correct bios on it?
https://linustechtips.com/topic/1083810-help-mobo/#findComment-12730394
Is there just a standard M-flash utility in the bios settings? If there is, flash the bios through that, usually the Dual Bios flash button that is physically on the board is to switch the bios to a version that isn't corrupt so that if you mess up your main bios you have a backup so that you don't brick the board. If you're just updating the bios normally you should just do it in the bios software with the flash utility in there.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1083810-help-mobo/#findComment-12730476
