RAM not running at correct speed or timing
Solved by GnB,
First look into your mobo manual, then enable the XMP profile you can choose.
Edit: If you are on a AMD Platform it is called D.O.C.P and not XMP, but in the end its the same just with another name.
Featured Topics
Bublito ·
Posted in Troubleshooting0 -
Siamshot ·
Posted in New Builds and Planning2 -
theolaa ·
Posted in Networking0 -
Marmitello ·
Gerowen ·
Meowth LVL255 ·
Posted in Cooling0 -
Quidsn ·
Posted in Graphics Cards3
