Your system probably won't use more than 400W under max load (including the monitor), if that, so you'd probably be fine with something around 1000VA/500W. You could go larger if you want extra on-time or room for more devices or more powerful devices in the future. Maybe a little smaller if you want to save money, but I wouldn't go below around a 500W output rating.
https://amzn.to/2XQhK7E Here's a solid option. CyberPower CP1000AVRLCD for $109.95
https://linustechtips.com/topic/1083670-ups/#findComment-12729189
