So my pc has an 110 gb ssd and a 300 gb hdd. It's quite enough for what I need but the thing is that the ssd divided into to partitions, it used to be just local disk c with 110 gigs but now i have a local disk c of 30gb and a local disk e of 80 gb and I'm running out of space on local disk c cus everything saves there for whatever reason even tho I choose to install most of the apps on my hdd. Is there a possibility for me to merge local disk c and e so i can have just the local disk c of 110 gb?
https://linustechtips.com/topic/1083369-ok-i-need-help/
You can wipe partitions you don't need and expand the C drive... but you will lose whatever data you had on those other partitions. I don't know of a way to do it without losing the data on the other partitions. You might be able to shrink the E partition, then expand the C though.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1083369-ok-i-need-help/#findComment-12726998
i can shrink disk E but it won't let me expand the C
https://linustechtips.com/topic/1083369-ok-i-need-help/#findComment-12727012
You probably cant expand C with the integrated partition program
Use this: https://www.easeus.de/partition-manager/partition-master-free.html
Does the job and is free
BUT DO A BACKUP!
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1083369-ok-i-need-help/#findComment-12727030
Ahh OK. The partitions might not be next to each other then, probably the recovery.... was just about to mention EASUS when @Metallus97 got there first :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1083369-ok-i-need-help/#findComment-12727034
