I'll be gaming, streaming, and recording at 1440p. The wireless card is a place holder as is the hard drive, but the rest is accurate. Whats everyone's thoughts? Also, that Trident Z Royal is the only 3600 speed ram I could find at 16 gig a stick to fit the build. Oh well
https://linustechtips.com/topic/1083320-current-3900x-build/
27 minutes ago, GamerTrem said:
I already bought the 3900X,
Transfer the Noctua NH U12A, 970 Evo, RTX 2080 and the BitFenix 550W from my "old build"
I'll recommend you to swap these parts...
PCPartPicker Part List
Motherboard: MSI - MPG X570 GAMING EDGE WIFI ATX AM4 Motherboard  ($209.99 @ B&H)
Memory: G.Skill - Sniper X 16 GB (2 x 8 GB) DDR4-3600 Memory  ($73.99 @ Newegg Business)
Storage: Seagate - Constellation ES 3 TB 3.5" 7200RPM Internal Hard Drive  ($56.99 @ Amazon)
Case: Cooler Master - MasterCase H500 ATX Mid Tower Case  ($99.99 @ Amazon)
Total: $440.96
Generated by PCPartPicker 2019-07-17 04:48 EDT-0400
GOLDEN CAT
Ryzen 5 2400g
Asrock AB350 PRO4
Gskill Ripjaws 4*2gb 3000mhz
HP EX920 512GB
Seagate barracuda 2000GB
Zotac 1080ti Amp Extreme
Fractal Design Meshify C
Cooler Master Masterwatt 550
https://linustechtips.com/topic/1083320-current-3900x-build/#findComment-12726659
the taichi already has wifi so no need for another wifi adapter.
https://linustechtips.com/topic/1083320-current-3900x-build/#findComment-12726668
Wifi card listed is because I have one currently, its more to match the power requirements than anything in the overall build for what little that matters, though with the onboard wifi for the Taichi it is already a lot faster with the newer tech. Which is part of why I chose the Taichi.
I have a total of 2TB of SSD and 2TB of HDD in my system atm, just didn't list them all. Though I plan on getting a larger HDD for video storage for later editing.
I am shooting for the higher end RAM and don't want to drop below the 32gigs as I stream, record,  and video edit, etc all at 1440p. Which is why I was shooting for the 3600 speed ram as well. Wanted to max that out for the 1:1 ratio.
I looked at the Meshify C, but that case is a little smaller than the S2 which I'd like to keep due to the building room it gives.
https://linustechtips.com/topic/1083320-current-3900x-build/#findComment-12726677
Total: $440.96
Why? Taichi is a very solid board.
also I would go with th fractal design case, or the S2. They are so good for airflow and they look nice.
as for the ram, should be a solid cheaper alternative
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1083320-current-3900x-build/#findComment-12726696
7 hours ago, GamerTrem said:
I am leaning towards a stronger power supply, but pcpartpicker shows I have roughly 100W breathing room atm. If I go for any heavier OC I'll make sure to upgrade the PSU.
The 3900X is a power hungry chip IIRC. I would upgrade the PSU to be sure.
https://linustechtips.com/topic/1083320-current-3900x-build/#findComment-12727559
