HELP! Game can only be played at 60hz on my 100hz monitor with elgato hd60s
Solved by DarthSmartt,
I figured out a work around. If i just have all three of my displays extended I can create a display capture(which doesn't use many resources if obs isnt streaming) in obs on my main pc and use fullscreen projector mode to project it to the hd60s. Then I can use my monitor at 2560x1080 at 100hz in games and record through elgato at 1920x1080p60.
This guy helped me out
