So I installed a Hyper 212 about a month ago. Its been working flawlessly for about 3 weeks, but then I went and installed a card reader and another fan, and that same day it started showing an error message saying "CPU Fan Error" and all I do is hit reset, and that causes it to boot to windows perfectly fine. When I go into BIOS when it says the error message, it says that the fan speed is dropping below 600 rpm, but once I reset and it goes into windows, my temps are fine. Ill be normally sitting at 28 degrees celcius. Any help is appreciated. Thanks
https://linustechtips.com/topic/108278-cpu-fan-error/
In the bios is there a way to turn off CPU fan error message or something like that? Also specs are helpful
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/108278-cpu-fan-error/#findComment-1447412
can you make sure all the fans are plugged in properly, as well as the power supply cables.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/108278-cpu-fan-error/#findComment-1447517
