hey guys
I was wondering if I should recommend to my boss if I should start mining with the system
the specs are,
3x Quadro m6000
2x 14 core xeon`s
at the moment it is being used for virtualisation during the day but during the night it is just sitting idle, should I mine or not?
thanks Tom
https://linustechtips.com/topic/1082626-mining-on-a-quadro/
On 7/15/2019 at 10:34 PM, Redicat said:
If your boss said yes then just do it cuz every little bit of folding performance helps even tho there are many budget cards that would do more than M6000 it does not matter at all just fold :)
i don't think he means folding, i think OP want's do do actual Bitcoin/altcoin mining on the system.
for actual mining i don't think you should use this system. the cost in power draw will likely be more than it will make in mined coins.
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12726602
dumb idea
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12728159
Depends what you mine.
There are a PLETHORA of coins that are exchangeable for BTC on the BTC Exchange.  Mining is not dead lol, its just not as easy as it used to be.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12728515
Mining is DEAD. period
until August that is...
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12730526
Says you, and that's fine.  Mining is not dead, certain TYPES of mining is however.  I mine both my CPU and GPU when not at home on my Ryzen Rigs because the coin I mine yields better results for exchange on the BTC market than the electricity costs.  And since the valuation on a Crypto is up to society, its worth the potential risk.
The fact you say period like you are a Subject Matter Expert is kind of funny.  But Im glad its dead to you, means the block chains wont be taken up by other people (like you)
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12730537
the fact is tough, for someone who asks a forum if he should mine he probably doesn't know what coins he should mine to turn a (marginal with the hardware) profit.
and since people who do know about a worthwile currency want as little people mining it as possible, i'm not counting on you to tell him what he should do, or profits for you go down potentially.
so what i'm trying to say is; 'should i mine?' is not a simple yes or no question. there's a lot more here that needs to be taken into consideration.
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12730609
100% agree to this - and you are right, I wouldn't divulge that information :) for the reason you are stating as the currency we utilize is infantile compared to others - but I/we have direct influence over its use-case in the Midwest of the USA :)
https://linustechtips.com/topic/1082626-mining-on-a-quadro/#findComment-12730720
