srsly, butter? above all else?
Desktop benching:
https://linustechtips.com/topic/1082213-fire-alarm/#findComment-12718594
2 minutes ago, hackgod said:
Meaning that the prongs will be separated by butter
so I assume it needs enough heat to melt the butter before the alarm triggers? That's quite a bad idea. Butter melts easily yes, but by the time it melts it has already missed the first sign of a fire, heavy smoke. Also if the applied place gets real hot outside, then this fire alarm will trigger when the air conditioning fails in a hot day too. Sure spraying down water will solve the heat issue, but I think there are bigger problems than heat at that point.
Desktop benching:
https://linustechtips.com/topic/1082213-fire-alarm/#findComment-12718676
